Time Before: 0.00199 seconds
Time After: 0.00255 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00267 seconds
Time After: 0.00304 seconds
Time Before: 0.00326 seconds
Time After: 0.00336 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00403 seconds
Time After: 0.00691 seconds
Time Taken: 0.00287 seconds
Time Before: 0.00341 seconds
Time After: 0.01029 seconds
Time Taken: 0.00689 seconds
Time Before: 0.01217 seconds
Time After: 0.01248 seconds
Time Before: 0.01462 seconds
Time After: 0.01587 seconds
Time Before: 0.01157 seconds
Time After: 0.01605 seconds
Time Taken: 0.00447 seconds
Memory After: 2,885.109 KB
Memory Used: 132.781 KB
Time Before: 0.02107 seconds
Time After: 0.02126 seconds
Memory Before: 3,438.211 KB
Memory After: 3,438.727 KB
Time Before: 0.02295 seconds
Time After: 0.02420 seconds
Memory Before: 3,525.906 KB
Memory After: 3,526.500 KB
End call of global.php: 0.025796890258789
Time Before: 0.02678 seconds
Time After: 0.02698 seconds
Memory Before: 4,163.813 KB
Memory After: 4,164.242 KB
Time Before: 0.02888 seconds
Time After: 0.03028 seconds
Time Taken: 0.00140 seconds
Memory Before: 4,445.375 KB
Memory After: 4,447.063 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=112613'
Time Before: 0.04255 seconds
Time After: 0.04292 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.041627883911133 seconds with 9 queries, spending 0.0083110332489014 doing MySQL queries and 0.033316850662231 doing PHP things.
