Time Before: 0.02404 seconds
Time After: 0.03067 seconds
Time Taken: 0.00664 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03078 seconds
Time After: 0.03121 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03144 seconds
Time After: 0.03158 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03255 seconds
Time After: 0.03550 seconds
Time Taken: 0.00294 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03166 seconds
Time After: 0.04006 seconds
Time Taken: 0.00840 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04658 seconds
Time After: 0.04699 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04933 seconds
Time After: 0.05054 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04582 seconds
Time After: 0.05075 seconds
Time Taken: 0.00493 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.09200 seconds
Time After: 0.09214 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.14288 seconds
Time After: 0.14415 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.16827 seconds
Time After: 0.16845 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.17186 seconds
Time After: 0.17332 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112638', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.19826 seconds
Time After: 0.19850 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
