Time Before: 0.00157 seconds
Time After: 0.00208 seconds
Time Before: 0.00216 seconds
Time After: 0.00267 seconds
Time Before: 0.00296 seconds
Time After: 0.00313 seconds
Time Before: 0.00403 seconds
Time After: 0.00668 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00321 seconds
Time After: 0.01007 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01220 seconds
Time After: 0.01262 seconds
Time Before: 0.01622 seconds
Time After: 0.01743 seconds
Time Before: 0.01151 seconds
Time After: 0.01761 seconds
Time Taken: 0.00610 seconds
Time Before: 0.02275 seconds
Time After: 0.02288 seconds
Time Before: 0.02500 seconds
Time After: 0.02625 seconds
Time Before: 0.02910 seconds
Time After: 0.02929 seconds
Time Before: 0.03137 seconds
Time After: 0.03279 seconds
UPDATE session SET lastactivity = 1788922252, location = '/forums/private.php?do=newpm&explain=1&u=112652' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04557 seconds
Time After: 0.04605 seconds
