Time Before: 0.01403 seconds
Time After: 0.01823 seconds
Time Taken: 0.00420 seconds
Time Before: 0.01832 seconds
Time After: 0.01912 seconds
Time Taken: 0.00080 seconds
Time Before: 0.01947 seconds
Time After: 0.01973 seconds
Time Before: 0.02046 seconds
Time After: 0.02331 seconds
Time Taken: 0.00285 seconds
Time Before: 0.01978 seconds
Time After: 0.02771 seconds
Time Taken: 0.00793 seconds
Time Before: 0.03372 seconds
Time After: 0.03409 seconds
Time Before: 0.03676 seconds
Time After: 0.03802 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03303 seconds
Time After: 0.03826 seconds
Time Taken: 0.00523 seconds
Memory After: 2,261.703 KB
Time Before: 0.06656 seconds
Time After: 0.06671 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08016 seconds
Time After: 0.08375 seconds
Time Taken: 0.00359 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09081 seconds
Time After: 0.09096 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09373 seconds
Time After: 0.09564 seconds
Time Taken: 0.00190 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112658' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.11384 seconds
Time After: 0.11409 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
