Time Before: 0.00216 seconds
Time After: 0.00266 seconds
Time Before: 0.00273 seconds
Time After: 0.00315 seconds
Time Before: 0.00338 seconds
Time After: 0.00360 seconds
Time Before: 0.00428 seconds
Time After: 0.00682 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00365 seconds
Time After: 0.01136 seconds
Time Taken: 0.00771 seconds
Time Before: 0.01368 seconds
Time After: 0.01406 seconds
Time Before: 0.01727 seconds
Time After: 0.01846 seconds
Time Before: 0.01306 seconds
Time After: 0.01869 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02376 seconds
Time After: 0.02390 seconds
Time Before: 0.02589 seconds
Time After: 0.02708 seconds
End call of global.php: 0.028748989105225
Time Before: 0.02998 seconds
Time After: 0.03012 seconds
Time Before: 0.03207 seconds
Time After: 0.03352 seconds
SET lastactivity = 1788972397, location = '/forums/private.php?do=newpm&explain=1&u=112660'
Time Before: 0.05050 seconds
Time After: 0.05077 seconds
Page generated in 0.049492120742798 seconds with 9 queries, spending 0.0079503059387207 doing MySQL queries and 0.041541814804077 doing PHP things.
