Time Before: 0.00143 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00238 seconds
Time Before: 0.00266 seconds
Time After: 0.00277 seconds
Time Before: 0.00348 seconds
Time After: 0.00835 seconds
Time Taken: 0.00487 seconds
Time Before: 0.00282 seconds
Time After: 0.01173 seconds
Time Taken: 0.00891 seconds
Time Before: 0.01348 seconds
Time After: 0.01391 seconds
Time Before: 0.01664 seconds
Time After: 0.01782 seconds
Time Before: 0.01293 seconds
Time After: 0.01799 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02312 seconds
Time After: 0.02333 seconds
Time Before: 0.02524 seconds
Time After: 0.02665 seconds
End call of global.php: 0.029254198074341
Time Before: 0.03086 seconds
Time After: 0.03156 seconds
Time Taken: 0.00069 seconds
Time Before: 0.03377 seconds
Time After: 0.03518 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112739'
Time Before: 0.04798 seconds
Time After: 0.04848 seconds
Page generated in 0.047089099884033 seconds with 9 queries, spending 0.011197090148926 doing MySQL queries and 0.035892009735107 doing PHP things.
