Time Before: 0.00207 seconds
Time After: 0.00275 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00287 seconds
Time After: 0.00337 seconds
Time Before: 0.00362 seconds
Time After: 0.00380 seconds
Time Before: 0.00480 seconds
Time After: 0.00736 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00390 seconds
Time After: 0.01363 seconds
Time Taken: 0.00974 seconds
Time Before: 0.01640 seconds
Time After: 0.01688 seconds
Time Before: 0.02023 seconds
Time After: 0.02142 seconds
Time Before: 0.01557 seconds
Time After: 0.02167 seconds
Time Taken: 0.00610 seconds
Time Before: 0.02723 seconds
Time After: 0.02736 seconds
Time Before: 0.02933 seconds
Time After: 0.03086 seconds
Time Taken: 0.00153 seconds
End call of global.php: 0.033431053161621
Time Before: 0.03585 seconds
Time After: 0.03606 seconds
Time Before: 0.03902 seconds
Time After: 0.04061 seconds
Time Taken: 0.00159 seconds
SET lastactivity = 1785280552, location = '/forums/private.php?do=newpm&explain=1&u=112744', badlocation = 1
Time Before: 0.05566 seconds
Time After: 0.05597 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.054710149765015 seconds with 9 queries, spending 0.0086739063262939 doing MySQL queries and 0.046036243438721 doing PHP things.
