Time Before: 0.00263 seconds
Time After: 0.00313 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00320 seconds
Time After: 0.00390 seconds
Time Taken: 0.00070 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00417 seconds
Time After: 0.00428 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00489 seconds
Time After: 0.00720 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00432 seconds
Time After: 0.01058 seconds
Time Taken: 0.00626 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01261 seconds
Time After: 0.01305 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01536 seconds
Time After: 0.01656 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01189 seconds
Time After: 0.01676 seconds
Time Taken: 0.00486 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02304 seconds
Time After: 0.02321 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"6.58,\";s:9:\"lastcheck\";i:1772951919;}', 1)
Time Before: 0.02880 seconds
Time After: 0.02950 seconds
Memory Before: 3,657.078 KB
Memory After: 3,657.328 KB
Memory Used: 0.250 KB
Time Before: 0.03703 seconds
Time After: 0.03826 seconds
Memory Before: 4,133.719 KB
Memory After: 4,134.313 KB
End call of global.php: 0.040333032608032
Time Before: 0.04708 seconds
Time After: 0.04733 seconds
Memory Before: 5,197.906 KB
Memory After: 5,326.250 KB
Time Before: 0.04980 seconds
Time After: 0.05128 seconds
Memory Before: 5,481.586 KB
Memory After: 5,611.188 KB
SET lastactivity = 1772951919, location = '/forums/private.php?do=newpm&explain=1&u=112770'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06494 seconds
Time After: 0.06525 seconds
Memory Before: 6,006.227 KB
Memory After: 6,006.445 KB
Page generated in 0.064013004302979 seconds with 10 queries, spending 0.0088980197906494 doing MySQL queries and 0.055114984512329 doing PHP things.
