Time Before: 0.00162 seconds
Time After: 0.00284 seconds
Time Before: 0.00298 seconds
Time After: 0.00353 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00388 seconds
Time After: 0.00402 seconds
Time Before: 0.00468 seconds
Time After: 0.00726 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00407 seconds
Time After: 0.01068 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01240 seconds
Time After: 0.01277 seconds
Time Before: 0.01525 seconds
Time After: 0.01644 seconds
Time Before: 0.01186 seconds
Time After: 0.01661 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02162 seconds
Time After: 0.02174 seconds
Time Before: 0.02378 seconds
Time After: 0.02507 seconds
End call of global.php: 0.026791095733643
Time Before: 0.02816 seconds
Time After: 0.02830 seconds
Time Before: 0.03030 seconds
Time After: 0.03175 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112777', badlocation = 1
Time Before: 0.04448 seconds
Time After: 0.04484 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.043576002120972 seconds with 9 queries, spending 0.0081777572631836 doing MySQL queries and 0.035398244857788 doing PHP things.
