Time Before: 0.02503 seconds
Time After: 0.03022 seconds
Time Taken: 0.00519 seconds
Time Before: 0.03031 seconds
Time After: 0.03077 seconds
Time Before: 0.03102 seconds
Time After: 0.03117 seconds
Time Before: 0.03196 seconds
Time After: 0.03418 seconds
Time Taken: 0.00222 seconds
Time Before: 0.03123 seconds
Time After: 0.03874 seconds
Time Taken: 0.00752 seconds
Time Before: 0.04456 seconds
Time After: 0.04498 seconds
Time Before: 0.04632 seconds
Time After: 0.04758 seconds
Time Before: 0.04385 seconds
Time After: 0.04782 seconds
Time Taken: 0.00397 seconds
Time Before: 0.07059 seconds
Time After: 0.07077 seconds
Time Before: 0.08862 seconds
Time After: 0.08985 seconds
Time Before: 0.10006 seconds
Time After: 0.10024 seconds
Time Before: 0.10278 seconds
Time After: 0.10426 seconds
UPDATE session SET lastactivity = 1776694034, location = '/forums/private.php?do=newpm&explain=1&u=112815', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.12781 seconds
Time After: 0.12814 seconds
