Time Before: 0.00624 seconds
Time After: 0.00818 seconds
Time Taken: 0.00194 seconds
Time Before: 0.00828 seconds
Time After: 0.00875 seconds
Time Before: 0.00897 seconds
Time After: 0.00912 seconds
Time Before: 0.00995 seconds
Time After: 0.01265 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00919 seconds
Time After: 0.01706 seconds
Time Taken: 0.00787 seconds
Time Before: 0.02147 seconds
Time After: 0.02190 seconds
Time Before: 0.02347 seconds
Time After: 0.02474 seconds
Time Before: 0.02077 seconds
Time After: 0.02498 seconds
Time Taken: 0.00421 seconds
Time Before: 0.04319 seconds
Time After: 0.04334 seconds
Time Before: 0.05154 seconds
Time After: 0.05280 seconds
End call of global.php: 0.055153131484985
Time Before: 0.05795 seconds
Time After: 0.05812 seconds
Time Before: 0.06096 seconds
Time After: 0.06248 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112937'
Time Before: 0.08129 seconds
Time After: 0.08175 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.079908132553101 seconds with 9 queries, spending 0.0085933208465576 doing MySQL queries and 0.071314811706543 doing PHP things.
