Time Before: 0.00144 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00241 seconds
Time Before: 0.00263 seconds
Time After: 0.00277 seconds
Time Before: 0.00349 seconds
Time After: 0.00695 seconds
Time Taken: 0.00346 seconds
Time Before: 0.00282 seconds
Time After: 0.01041 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01268 seconds
Time After: 0.01311 seconds
Time Before: 0.01659 seconds
Time After: 0.01777 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01196 seconds
Time After: 0.01795 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02281 seconds
Time After: 0.02316 seconds
Time Before: 0.02508 seconds
Time After: 0.02633 seconds
End call of global.php: 0.027935028076172
Time Before: 0.02925 seconds
Time After: 0.02939 seconds
Time Before: 0.03140 seconds
Time After: 0.03280 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112995', badlocation = 1
Time Before: 0.04503 seconds
Time After: 0.04532 seconds
Page generated in 0.044142007827759 seconds with 9 queries, spending 0.0091443061828613 doing MySQL queries and 0.034997701644897 doing PHP things.
