Time Before: 0.00152 seconds
Time After: 0.00211 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00218 seconds
Time After: 0.00269 seconds
Time Before: 0.00296 seconds
Time After: 0.00314 seconds
Time Before: 0.00401 seconds
Time After: 0.00662 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00322 seconds
Time After: 0.01167 seconds
Time Taken: 0.00845 seconds
Time Before: 0.01383 seconds
Time After: 0.01405 seconds
Time Before: 0.01678 seconds
Time After: 0.01804 seconds
Time Before: 0.01322 seconds
Time After: 0.01834 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02494 seconds
Time After: 0.02512 seconds
Time Before: 0.88659 seconds
Time After: 0.88885 seconds
Time Taken: 0.00226 seconds
Time Before: 0.89312 seconds
Time After: 0.89327 seconds
Time Before: 0.89656 seconds
Time After: 0.89804 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113000', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.91556 seconds
Time After: 0.91581 seconds
