Time Before: 0.01183 seconds
Time After: 0.01524 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01535 seconds
Time After: 0.01650 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01716 seconds
Time After: 0.01732 seconds
Time Before: 0.01808 seconds
Time After: 0.02012 seconds
Time Taken: 0.00204 seconds
Time Before: 0.01737 seconds
Time After: 0.02419 seconds
Time Taken: 0.00682 seconds
Time Before: 0.02930 seconds
Time After: 0.02947 seconds
Time Before: 0.03095 seconds
Time After: 0.03215 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02852 seconds
Time After: 0.03233 seconds
Time Taken: 0.00381 seconds
Memory After: 2,261.703 KB
Time Before: 0.05250 seconds
Time After: 0.05261 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06138 seconds
Time After: 0.06258 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.064661026000977
Time Before: 0.06941 seconds
Time After: 0.06957 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07241 seconds
Time After: 0.07385 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=113007', badlocation = 1
Time Before: 0.09003 seconds
Time After: 0.09025 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.089000940322876 seconds with 9 queries, spending 0.0078451633453369 doing MySQL queries and 0.081155776977539 doing PHP things.
