Time Before: 0.00138 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00243 seconds
Time Before: 0.00267 seconds
Time After: 0.00284 seconds
Time Before: 0.00348 seconds
Time After: 0.00607 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00289 seconds
Time After: 0.00951 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01143 seconds
Time After: 0.01182 seconds
Time Before: 0.01450 seconds
Time After: 0.01581 seconds
Time Before: 0.01083 seconds
Time After: 0.01599 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02087 seconds
Time After: 0.02101 seconds
Time Before: 0.02304 seconds
Time After: 0.02433 seconds
Time Before: 0.02828 seconds
Time After: 0.02875 seconds
Time Before: 0.03143 seconds
Time After: 0.03290 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11304', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04865 seconds
Time After: 0.04919 seconds
Time Taken: 0.00053 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
