Time Before: 0.02340 seconds
Time After: 0.03067 seconds
Time Taken: 0.00726 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03078 seconds
Time After: 0.03140 seconds
Time Taken: 0.00062 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03162 seconds
Time After: 0.03175 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03267 seconds
Time After: 0.03622 seconds
Time Taken: 0.00355 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03180 seconds
Time After: 0.04035 seconds
Time Taken: 0.00855 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.04850 seconds
Time After: 0.04873 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05195 seconds
Time After: 0.05316 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.04769 seconds
Time After: 0.05339 seconds
Time Taken: 0.00570 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.07987 seconds
Time After: 0.08002 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10176 seconds
Time After: 0.10302 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.11353 seconds
Time After: 0.11366 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.11608 seconds
Time After: 0.11749 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1783125153, location = '/forums/private.php?do=newpm&explain=1&u=113052', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.13541 seconds
Time After: 0.13564 seconds
Memory Before: 4,296.930 KB
Memory After: 4,297.141 KB
