Time Before: 0.00236 seconds
Time After: 0.00342 seconds
Time Taken: 0.00105 seconds
Time Before: 0.00352 seconds
Time After: 0.00391 seconds
Time Before: 0.00412 seconds
Time After: 0.00425 seconds
Time Before: 0.00516 seconds
Time After: 0.00797 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00432 seconds
Time After: 0.01341 seconds
Time Taken: 0.00909 seconds
Time Before: 0.01576 seconds
Time After: 0.01620 seconds
Time Before: 0.01939 seconds
Time After: 0.02059 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01507 seconds
Time After: 0.02084 seconds
Time Taken: 0.00577 seconds
Memory After: 2,261.703 KB
Time Before: 0.02750 seconds
Time After: 0.02769 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02981 seconds
Time After: 0.03120 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.033801078796387
Time Before: 0.03535 seconds
Time After: 0.03553 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03860 seconds
Time After: 0.04009 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=113094', badlocation = 1
Time Before: 0.05377 seconds
Time After: 0.05418 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.05279803276062 seconds with 9 queries, spending 0.0086185932159424 doing MySQL queries and 0.044179439544678 doing PHP things.
