Time Before: 0.00132 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00229 seconds
Time Before: 0.00254 seconds
Time After: 0.00270 seconds
Time Before: 0.00342 seconds
Time After: 0.00647 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00275 seconds
Time After: 0.00990 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01175 seconds
Time After: 0.01209 seconds
Time Before: 0.01344 seconds
Time After: 0.01472 seconds
Time Before: 0.01117 seconds
Time After: 0.01499 seconds
Time Taken: 0.00383 seconds
Time Before: 0.02173 seconds
Time After: 0.02190 seconds
Time Before: 0.02400 seconds
Time After: 0.02527 seconds
End call of global.php: 0.027143001556396
Time Before: 0.02830 seconds
Time After: 0.02848 seconds
Time Before: 0.03059 seconds
Time After: 0.03201 seconds
SET lastactivity = 1785301753, location = '/forums/private.php?do=newpm&explain=1&u=11317'
Time Before: 0.04441 seconds
Time After: 0.04477 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.043500900268555 seconds with 9 queries, spending 0.0086283683776855 doing MySQL queries and 0.034872531890869 doing PHP things.
