Time Before: 0.02521 seconds
Time After: 0.03101 seconds
Time Taken: 0.00581 seconds
Time Before: 0.03111 seconds
Time After: 0.03163 seconds
Time Before: 0.03190 seconds
Time After: 0.03206 seconds
Time Before: 0.03277 seconds
Time After: 0.03476 seconds
Time Taken: 0.00198 seconds
Time Before: 0.03212 seconds
Time After: 0.03907 seconds
Time Taken: 0.00695 seconds
Time Before: 0.05021 seconds
Time After: 0.05064 seconds
Time Before: 0.05202 seconds
Time After: 0.05321 seconds
Time Before: 0.04948 seconds
Time After: 0.05340 seconds
Time Taken: 0.00392 seconds
Time Before: 0.10328 seconds
Time After: 0.10341 seconds
Time Before: 0.12304 seconds
Time After: 0.12430 seconds
Time Before: 0.13736 seconds
Time After: 0.13749 seconds
Time Before: 0.13997 seconds
Time After: 0.14141 seconds
UPDATE session SET lastactivity = 1784881394, location = '/forums/private.php?do=newpm&explain=1&u=113194' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.16151 seconds
Time After: 0.16180 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
