Time Before: 0.02536 seconds
Time After: 0.03370 seconds
Time Taken: 0.00834 seconds
Time Before: 0.03382 seconds
Time After: 0.03432 seconds
Time Before: 0.03458 seconds
Time After: 0.03472 seconds
Time Before: 0.03552 seconds
Time After: 0.03815 seconds
Time Taken: 0.00263 seconds
Time Before: 0.03480 seconds
Time After: 0.04366 seconds
Time Taken: 0.00886 seconds
Time Before: 0.05560 seconds
Time After: 0.05593 seconds
Time Before: 0.05797 seconds
Time After: 0.05935 seconds
Time Taken: 0.00139 seconds
Time Before: 0.05496 seconds
Time After: 0.05962 seconds
Time Taken: 0.00467 seconds
Time Before: 0.09809 seconds
Time After: 0.09826 seconds
Time Before: 0.12914 seconds
Time After: 0.13038 seconds
Time Before: 0.14603 seconds
Time After: 0.14620 seconds
Time Before: 0.14897 seconds
Time After: 0.15040 seconds
UPDATE session SET lastactivity = 1785268095, location = '/forums/private.php?do=newpm&explain=1&u=113197' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.16986 seconds
Time After: 0.17011 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
