Time Before: 0.00209 seconds
Time After: 0.00274 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00281 seconds
Time After: 0.00318 seconds
Time Before: 0.00336 seconds
Time After: 0.00346 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00414 seconds
Time After: 0.00658 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00351 seconds
Time After: 0.01155 seconds
Time Taken: 0.00804 seconds
Time Before: 0.01379 seconds
Time After: 0.01416 seconds
Time Before: 0.01635 seconds
Time After: 0.01765 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01307 seconds
Time After: 0.01790 seconds
Time Taken: 0.00482 seconds
Memory After: 2,261.703 KB
Time Before: 0.02425 seconds
Time After: 0.02444 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02684 seconds
Time After: 0.02810 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.030482053756714
Time Before: 0.03186 seconds
Time After: 0.03202 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03480 seconds
Time After: 0.03625 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=113244'
Time Before: 0.05291 seconds
Time After: 0.05331 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.051980972290039 seconds with 9 queries, spending 0.0080335140228271 doing MySQL queries and 0.043947458267212 doing PHP things.
