Time Before: 0.00138 seconds
Time After: 0.00189 seconds
Time Before: 0.00197 seconds
Time After: 0.00251 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00301 seconds
Time After: 0.00314 seconds
Time Before: 0.00396 seconds
Time After: 0.00642 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00322 seconds
Time After: 0.01072 seconds
Time Taken: 0.00749 seconds
Time Before: 0.01278 seconds
Time After: 0.01333 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01498 seconds
Time After: 0.01622 seconds
Time Before: 0.01206 seconds
Time After: 0.01644 seconds
Time Taken: 0.00438 seconds
Time Before: 0.02320 seconds
Time After: 0.02333 seconds
Time Before: 0.02532 seconds
Time After: 0.02657 seconds
Time Before: 0.03079 seconds
Time After: 0.03103 seconds
Time Before: 0.03408 seconds
Time After: 0.03556 seconds
UPDATE session SET lastactivity = 1789125390, location = '/forums/private.php?do=newpm&explain=1&u=113338', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04852 seconds
Time After: 0.04888 seconds
