Time Before: 0.00663 seconds
Time After: 0.00781 seconds
Time Taken: 0.00118 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00791 seconds
Time After: 0.00855 seconds
Time Taken: 0.00064 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00879 seconds
Time After: 0.00891 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00955 seconds
Time After: 0.01222 seconds
Time Taken: 0.00267 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00896 seconds
Time After: 0.01561 seconds
Time Taken: 0.00665 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01829 seconds
Time After: 0.01865 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.02104 seconds
Time After: 0.02227 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01776 seconds
Time After: 0.02253 seconds
Time Taken: 0.00477 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.03724 seconds
Time After: 0.03739 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.04246 seconds
Time After: 0.04372 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.045444965362549
Time Before: 0.04797 seconds
Time After: 0.04810 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.05006 seconds
Time After: 0.05147 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1785288713, location = '/forums/private.php?do=newpm&explain=1&u=113340'
Time Before: 0.06408 seconds
Time After: 0.06434 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.063199996948242 seconds with 9 queries, spending 0.0082459449768066 doing MySQL queries and 0.054954051971436 doing PHP things.
