Time Before: 0.01235 seconds
Time After: 0.01576 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01586 seconds
Time After: 0.01631 seconds
Time Before: 0.01674 seconds
Time After: 0.01690 seconds
Time Before: 0.01783 seconds
Time After: 0.02065 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01697 seconds
Time After: 0.02432 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03179 seconds
Time After: 0.03226 seconds
Time Before: 0.03504 seconds
Time After: 0.03633 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03105 seconds
Time After: 0.03653 seconds
Time Taken: 0.00548 seconds
Memory After: 2,261.820 KB
Time Before: 0.05807 seconds
Time After: 0.05862 seconds
Time Taken: 0.00054 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.35578 seconds
Time After: 0.35717 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.37053 seconds
Time After: 0.37069 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.37359 seconds
Time After: 0.37515 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789142826, location = '/forums/private.php?do=newpm&explain=1&u=113377', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.39569 seconds
Time After: 0.39599 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
