Time Before: 0.00134 seconds
Time After: 0.00195 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00203 seconds
Time After: 0.00252 seconds
Time Before: 0.00279 seconds
Time After: 0.00298 seconds
Time Before: 0.00386 seconds
Time After: 0.00606 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00306 seconds
Time After: 0.01086 seconds
Time Taken: 0.00780 seconds
Time Before: 0.01280 seconds
Time After: 0.01320 seconds
Time Before: 0.01608 seconds
Time After: 0.01762 seconds
Time Taken: 0.00153 seconds
Time Before: 0.01205 seconds
Time After: 0.01786 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02450 seconds
Time After: 0.02476 seconds
Time Before: 0.02725 seconds
Time After: 0.02896 seconds
Time Taken: 0.00172 seconds
Time Before: 0.03305 seconds
Time After: 0.03325 seconds
Time Before: 0.03618 seconds
Time After: 0.03771 seconds
UPDATE session SET lastactivity = 1788904324, location = '/forums/private.php?do=newpm&explain=1&u=113405' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05081 seconds
Time After: 0.05112 seconds
