Time Before: 0.00628 seconds
Time After: 0.01028 seconds
Time Taken: 0.00400 seconds
Time Before: 0.01036 seconds
Time After: 0.01080 seconds
Time Before: 0.01100 seconds
Time After: 0.01114 seconds
Time Before: 0.01196 seconds
Time After: 0.01476 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01122 seconds
Time After: 0.01982 seconds
Time Taken: 0.00859 seconds
Time Before: 0.02569 seconds
Time After: 0.02614 seconds
Time Before: 0.02870 seconds
Time After: 0.02994 seconds
Time Before: 0.02494 seconds
Time After: 0.03017 seconds
Time Taken: 0.00524 seconds
Time Before: 0.04338 seconds
Time After: 0.04355 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"15.62,\";s:9:\"lastcheck\";i:1783059577;}', 1)Time Before: 0.05947 seconds
Time After: 0.06001 seconds
Time Taken: 0.00054 seconds
Memory Before: 2,817.297 KB
Memory After: 2,817.547 KB
Memory Used: 0.250 KB
Time Before: 0.07109 seconds
Time After: 0.07235 seconds
Memory Before: 2,904.602 KB
Memory After: 2,905.195 KB
Time Before: 0.08113 seconds
Time After: 0.08132 seconds
Memory Before: 3,541.359 KB
Memory After: 3,541.789 KB
Time Before: 0.08462 seconds
Time After: 0.08706 seconds
Time Taken: 0.00245 seconds
Memory Before: 3,823.094 KB
Memory After: 3,824.781 KB
UPDATE session SET lastactivity = 1783059577, location = '/forums/private.php?do=newpm&explain=1&u=113407' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.10719 seconds
Time After: 0.10747 seconds
Memory Before: 4,296.805 KB
Memory After: 4,297.031 KB
