Time Before: 0.01376 seconds
Time After: 0.01656 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01663 seconds
Time After: 0.01706 seconds
Time Before: 0.01747 seconds
Time After: 0.01762 seconds
Time Before: 0.01864 seconds
Time After: 0.02132 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01770 seconds
Time After: 0.02581 seconds
Time Taken: 0.00811 seconds
Time Before: 0.03513 seconds
Time After: 0.03556 seconds
Time Before: 0.03895 seconds
Time After: 0.04022 seconds
Time Before: 0.03428 seconds
Time After: 0.04046 seconds
Time Taken: 0.00617 seconds
Time Before: 0.06884 seconds
Time After: 0.06897 seconds
Time Before: 0.07983 seconds
Time After: 0.08110 seconds
End call of global.php: 0.08367395401001
Time Before: 0.08978 seconds
Time After: 0.08995 seconds
Time Before: 0.09253 seconds
Time After: 0.09400 seconds
SET lastactivity = 1784774849, location = '/forums/private.php?do=newpm&explain=1&u=113431', badlocation = 1
Time Before: 0.11010 seconds
Time After: 0.11045 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.10896992683411 seconds with 9 queries, spending 0.0083541870117188 doing MySQL queries and 0.10061573982239 doing PHP things.
