Time Before: 0.02872 seconds
Time After: 0.03534 seconds
Time Taken: 0.00663 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03546 seconds
Time After: 0.03594 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03621 seconds
Time After: 0.03640 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03720 seconds
Time After: 0.03970 seconds
Time Taken: 0.00250 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03647 seconds
Time After: 0.04371 seconds
Time Taken: 0.00724 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05342 seconds
Time After: 0.05381 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05637 seconds
Time After: 0.05755 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.05263 seconds
Time After: 0.05782 seconds
Time Taken: 0.00518 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.11352 seconds
Time After: 0.11369 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.19691 seconds
Time After: 0.19817 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
Time Before: 0.24013 seconds
Time After: 0.24034 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.24726 seconds
Time After: 0.24880 seconds
Time Taken: 0.00154 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113452', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.28623 seconds
Time After: 0.28649 seconds
Memory Before: 5,997.781 KB
Memory After: 5,998.008 KB
