Time Before: 0.00143 seconds
Time After: 0.00194 seconds
Time Before: 0.00204 seconds
Time After: 0.00251 seconds
Time Before: 0.00297 seconds
Time After: 0.00321 seconds
Time Before: 0.00407 seconds
Time After: 0.00698 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00329 seconds
Time After: 0.01073 seconds
Time Taken: 0.00744 seconds
Time Before: 0.01288 seconds
Time After: 0.01335 seconds
Time Before: 0.01626 seconds
Time After: 0.01804 seconds
Time Taken: 0.00179 seconds
Time Before: 0.01226 seconds
Time After: 0.01823 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02329 seconds
Time After: 0.02343 seconds
Time Before: 0.02520 seconds
Time After: 0.02646 seconds
Time Before: 0.03024 seconds
Time After: 0.03046 seconds
Time Before: 0.03473 seconds
Time After: 0.03733 seconds
Time Taken: 0.00259 seconds
UPDATE session SET lastactivity = 1789039093, location = '/forums/private.php?do=newpm&explain=1&u=113468', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05162 seconds
Time After: 0.05201 seconds
