Time Before: 0.00975 seconds
Time After: 0.01421 seconds
Time Taken: 0.00447 seconds
Time Before: 0.01433 seconds
Time After: 0.01482 seconds
Time Before: 0.01508 seconds
Time After: 0.01523 seconds
Time Before: 0.01608 seconds
Time After: 0.01867 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01530 seconds
Time After: 0.02261 seconds
Time Taken: 0.00731 seconds
Time Before: 0.02652 seconds
Time After: 0.02691 seconds
Time Before: 0.02946 seconds
Time After: 0.03070 seconds
Time Before: 0.02589 seconds
Time After: 0.03096 seconds
Time Taken: 0.00507 seconds
Time Before: 0.04858 seconds
Time After: 0.04876 seconds
Time Before: 0.06022 seconds
Time After: 0.06148 seconds
End call of global.php: 0.063612937927246
Time Before: 0.06972 seconds
Time After: 0.06986 seconds
Time Before: 0.07250 seconds
Time After: 0.07396 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=113476', badlocation = 1
Time Before: 0.09111 seconds
Time After: 0.09135 seconds
Page generated in 0.089962959289551 seconds with 9 queries, spending 0.008145809173584 doing MySQL queries and 0.081817150115967 doing PHP things.
