Time Before: 0.00148 seconds
Time After: 0.00199 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00206 seconds
Time After: 0.00254 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00286 seconds
Time After: 0.00298 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00381 seconds
Time After: 0.00698 seconds
Time Taken: 0.00317 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00306 seconds
Time After: 0.01074 seconds
Time Taken: 0.00768 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.01303 seconds
Time After: 0.01348 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.01675 seconds
Time After: 0.01808 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.01220 seconds
Time After: 0.01837 seconds
Time Taken: 0.00617 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.02597 seconds
Time After: 0.02615 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
Time Before: 0.02810 seconds
Time After: 0.02933 seconds
Memory Before: 3,524.281 KB
Memory After: 3,524.875 KB
Time Before: 0.03262 seconds
Time After: 0.03282 seconds
Memory Before: 4,162.195 KB
Memory After: 4,162.625 KB
Time Before: 0.03492 seconds
Time After: 0.03639 seconds
Memory Before: 4,443.734 KB
Memory After: 4,445.422 KB
UPDATE session SET lastactivity = 1785383735, location = '/forums/private.php?do=newpm&explain=1&u=113497' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05236 seconds
Time After: 0.05507 seconds
Time Taken: 0.00270 seconds
Memory Before: 4,922.039 KB
Memory After: 4,922.266 KB
