Time Before: 0.00161 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00257 seconds
Time Before: 0.00281 seconds
Time After: 0.00293 seconds
Time Before: 0.00386 seconds
Time After: 0.00620 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00300 seconds
Time After: 0.00964 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01144 seconds
Time After: 0.01188 seconds
Time Before: 0.01488 seconds
Time After: 0.01612 seconds
Time Before: 0.01084 seconds
Time After: 0.01633 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02158 seconds
Time After: 0.02172 seconds
Time Before: 0.02434 seconds
Time After: 0.02558 seconds
End call of global.php: 0.027971982955933
Time Before: 0.02935 seconds
Time After: 0.02948 seconds
Time Before: 0.03200 seconds
Time After: 0.03347 seconds
SET lastactivity = 1789140360, location = '/forums/private.php?do=newpm&explain=1&u=113506', badlocation = 1
Time Before: 0.04923 seconds
Time After: 0.04955 seconds
Page generated in 0.048098087310791 seconds with 9 queries, spending 0.0078895092010498 doing MySQL queries and 0.040208578109741 doing PHP things.
