Time Before: 0.00728 seconds
Time After: 0.01096 seconds
Time Taken: 0.00368 seconds
Time Before: 0.01108 seconds
Time After: 0.01157 seconds
Time Before: 0.01185 seconds
Time After: 0.01199 seconds
Time Before: 0.01281 seconds
Time After: 0.01495 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01206 seconds
Time After: 0.01910 seconds
Time Taken: 0.00704 seconds
Time Before: 0.02400 seconds
Time After: 0.02443 seconds
Time Before: 0.02599 seconds
Time After: 0.02715 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02328 seconds
Time After: 0.02737 seconds
Time Taken: 0.00409 seconds
Memory After: 2,261.820 KB
Time Before: 0.03953 seconds
Time After: 0.03968 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.04859 seconds
Time After: 0.04985 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.05601 seconds
Time After: 0.05615 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.05887 seconds
Time After: 0.06040 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788962508, location = '/forums/private.php?do=newpm&explain=1&u=113662', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.08074 seconds
Time After: 0.08105 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
