Time Before: 0.01426 seconds
Time After: 0.01997 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02005 seconds
Time After: 0.02048 seconds
Time Before: 0.02071 seconds
Time After: 0.02083 seconds
Time Before: 0.02149 seconds
Time After: 0.02453 seconds
Time Taken: 0.00304 seconds
Time Before: 0.02090 seconds
Time After: 0.03001 seconds
Time Taken: 0.00912 seconds
Time Before: 0.03795 seconds
Time After: 0.03839 seconds
Time Before: 0.04119 seconds
Time After: 0.04246 seconds
Time Before: 0.03710 seconds
Time After: 0.04268 seconds
Time Taken: 0.00558 seconds
Time Before: 0.07447 seconds
Time After: 0.07463 seconds
Time Before: 0.09398 seconds
Time After: 0.09525 seconds
Time Before: 0.10822 seconds
Time After: 0.10843 seconds
Time Before: 0.11135 seconds
Time After: 0.11280 seconds
UPDATE session SET lastactivity = 1784791780, location = '/forums/private.php?do=newpm&explain=1&u=113698' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.13583 seconds
Time After: 0.13625 seconds
