Time Before: 0.01591 seconds
Time After: 0.02224 seconds
Time Taken: 0.00633 seconds
Time Before: 0.02233 seconds
Time After: 0.02276 seconds
Time Before: 0.02304 seconds
Time After: 0.02318 seconds
Time Before: 0.02411 seconds
Time After: 0.02646 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02324 seconds
Time After: 0.03061 seconds
Time Taken: 0.00738 seconds
Time Before: 0.03633 seconds
Time After: 0.03689 seconds
Time Taken: 0.00055 seconds
Time Before: 0.04032 seconds
Time After: 0.04153 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03554 seconds
Time After: 0.04173 seconds
Time Taken: 0.00619 seconds
Memory After: 2,261.836 KB
Memory Used: 132.898 KB
Time Before: 0.06124 seconds
Time After: 0.06139 seconds
Memory Before: 2,815.383 KB
Memory After: 2,815.898 KB
Time Before: 0.07424 seconds
Time After: 0.07548 seconds
Memory Before: 2,903.578 KB
Memory After: 2,904.172 KB
End call of global.php: 0.078019857406616
Time Before: 0.08526 seconds
Time After: 0.08542 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08811 seconds
Time After: 0.08962 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET lastactivity = 1788970200, location = '/forums/private.php?do=newpm&explain=1&u=113699'
Time Before: 0.10574 seconds
Time After: 0.10652 seconds
Time Taken: 0.00078 seconds
Memory Before: 4,288.375 KB
Memory After: 4,288.602 KB
Page generated in 0.10457801818848 seconds with 9 queries, spending 0.0085504055023193 doing MySQL queries and 0.096027612686157 doing PHP things.
