Time Before: 0.00143 seconds
Time After: 0.00196 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00203 seconds
Time After: 0.00257 seconds
Time Before: 0.00281 seconds
Time After: 0.00295 seconds
Time Before: 0.00361 seconds
Time After: 0.00607 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00300 seconds
Time After: 0.01062 seconds
Time Taken: 0.00762 seconds
Time Before: 0.01303 seconds
Time After: 0.01344 seconds
Time Before: 0.01489 seconds
Time After: 0.01615 seconds
Time Before: 0.01232 seconds
Time After: 0.01639 seconds
Time Taken: 0.00408 seconds
Time Before: 0.02273 seconds
Time After: 0.02287 seconds
Time Before: 0.02509 seconds
Time After: 0.02635 seconds
End call of global.php: 0.029053211212158
Time Before: 0.03037 seconds
Time After: 0.03052 seconds
Time Before: 0.03347 seconds
Time After: 0.03492 seconds
SET lastactivity = 1776558573, location = '/forums/private.php?do=newpm&explain=1&u=1137', badlocation = 1
Time Before: 0.04897 seconds
Time After: 0.04929 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
Page generated in 0.048054218292236 seconds with 9 queries, spending 0.0081558227539062 doing MySQL queries and 0.03989839553833 doing PHP things.
