Time Before: 0.01102 seconds
Time After: 0.01377 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01388 seconds
Time After: 0.01432 seconds
Time Before: 0.01456 seconds
Time After: 0.01469 seconds
Time Before: 0.01568 seconds
Time After: 0.01783 seconds
Time Taken: 0.00215 seconds
Time Before: 0.01477 seconds
Time After: 0.02323 seconds
Time Taken: 0.00846 seconds
Time Before: 0.02901 seconds
Time After: 0.02939 seconds
Time Before: 0.03248 seconds
Time After: 0.03368 seconds
Time Before: 0.02832 seconds
Time After: 0.03387 seconds
Time Taken: 0.00555 seconds
Time Before: 0.05196 seconds
Time After: 0.05209 seconds
Time Before: 0.06210 seconds
Time After: 0.06337 seconds
End call of global.php: 0.065730094909668
Time Before: 0.07020 seconds
Time After: 0.07035 seconds
Time Before: 0.07346 seconds
Time After: 0.07489 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=113712', badlocation = 1
Time Before: 0.09263 seconds
Time After: 0.09296 seconds
Page generated in 0.091493129730225 seconds with 9 queries, spending 0.0076186656951904 doing MySQL queries and 0.083874464035034 doing PHP things.
