Time Before: 0.01690 seconds
Time After: 0.02089 seconds
Time Taken: 0.00399 seconds
Time Before: 0.02099 seconds
Time After: 0.02150 seconds
Time Before: 0.02175 seconds
Time After: 0.02189 seconds
Time Before: 0.02282 seconds
Time After: 0.02540 seconds
Time Taken: 0.00257 seconds
Time Before: 0.02196 seconds
Time After: 0.02967 seconds
Time Taken: 0.00771 seconds
Time Before: 0.03558 seconds
Time After: 0.03613 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03956 seconds
Time After: 0.04075 seconds
Time Before: 0.03482 seconds
Time After: 0.04095 seconds
Time Taken: 0.00613 seconds
Time Before: 0.07452 seconds
Time After: 0.07471 seconds
Time Before: 0.08969 seconds
Time After: 0.09098 seconds
Time Before: 0.09974 seconds
Time After: 0.09993 seconds
Time Before: 0.10258 seconds
Time After: 0.10405 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113718' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.12220 seconds
Time After: 0.12243 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
