Time Before: 0.01414 seconds
Time After: 0.01928 seconds
Time Taken: 0.00514 seconds
Time Before: 0.01937 seconds
Time After: 0.01982 seconds
Time Before: 0.02003 seconds
Time After: 0.02015 seconds
Time Before: 0.02091 seconds
Time After: 0.02359 seconds
Time Taken: 0.00268 seconds
Time Before: 0.02022 seconds
Time After: 0.02756 seconds
Time Taken: 0.00734 seconds
Time Before: 0.03496 seconds
Time After: 0.03535 seconds
Time Before: 0.03687 seconds
Time After: 0.03804 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03434 seconds
Time After: 0.03825 seconds
Time Taken: 0.00392 seconds
Time Before: 0.05572 seconds
Time After: 0.05585 seconds
Time Before: 0.07240 seconds
Time After: 0.07365 seconds
End call of global.php: 0.076181888580322
Time Before: 0.08530 seconds
Time After: 0.08549 seconds
Time Before: 0.08839 seconds
Time After: 0.08986 seconds
SET lastactivity = 1776447792, location = '/forums/private.php?do=newpm&explain=1&u=113720', badlocation = 1
Time Before: 0.10886 seconds
Time After: 0.10916 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.10787987709045 seconds with 9 queries, spending 0.0081491470336914 doing MySQL queries and 0.099730730056763 doing PHP things.
