Time Before: 0.02604 seconds
Time After: 0.03015 seconds
Time Taken: 0.00412 seconds
Time Before: 0.03025 seconds
Time After: 0.03064 seconds
Time Before: 0.03085 seconds
Time After: 0.03097 seconds
Time Before: 0.03188 seconds
Time After: 0.03378 seconds
Time Taken: 0.00190 seconds
Time Before: 0.03104 seconds
Time After: 0.03805 seconds
Time Taken: 0.00701 seconds
Time Before: 0.04767 seconds
Time After: 0.04811 seconds
Time Before: 0.05104 seconds
Time After: 0.05224 seconds
Time Before: 0.04695 seconds
Time After: 0.05257 seconds
Time Taken: 0.00562 seconds
Time Before: 0.08318 seconds
Time After: 0.08381 seconds
Time Taken: 0.00063 seconds
Time Before: 0.25070 seconds
Time After: 0.25200 seconds
Time Before: 0.26111 seconds
Time After: 0.26126 seconds
Time Before: 0.26431 seconds
Time After: 0.26575 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113728', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.28389 seconds
Time After: 0.28417 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
