Time Before: 0.01242 seconds
Time After: 0.01637 seconds
Time Taken: 0.00395 seconds
Time Before: 0.01645 seconds
Time After: 0.01686 seconds
Time Before: 0.01707 seconds
Time After: 0.01721 seconds
Time Before: 0.01796 seconds
Time After: 0.02046 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01727 seconds
Time After: 0.02530 seconds
Time Taken: 0.00803 seconds
Time Before: 0.03103 seconds
Time After: 0.03151 seconds
Time Before: 0.03317 seconds
Time After: 0.03442 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03029 seconds
Time After: 0.03470 seconds
Time Taken: 0.00441 seconds
Memory After: 2,261.820 KB
Time Before: 0.05731 seconds
Time After: 0.05749 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07134 seconds
Time After: 0.07262 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08110 seconds
Time After: 0.08127 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08417 seconds
Time After: 0.08560 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789115451, location = '/forums/private.php?do=newpm&explain=1&u=113753' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10447 seconds
Time After: 0.10494 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
