Time Before: 0.00431 seconds
Time After: 0.00600 seconds
Time Taken: 0.00169 seconds
Time Before: 0.00610 seconds
Time After: 0.00657 seconds
Time Before: 0.00680 seconds
Time After: 0.00694 seconds
Time Before: 0.00777 seconds
Time After: 0.01070 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00699 seconds
Time After: 0.01658 seconds
Time Taken: 0.00958 seconds
Time Before: 0.01950 seconds
Time After: 0.01969 seconds
Time Before: 0.02233 seconds
Time After: 0.02351 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01873 seconds
Time After: 0.02368 seconds
Time Taken: 0.00495 seconds
Time Before: 0.03033 seconds
Time After: 0.03046 seconds
Time Before: 0.06680 seconds
Time After: 0.06807 seconds
End call of global.php: 0.070786952972412
Time Before: 0.07229 seconds
Time After: 0.07248 seconds
Time Before: 0.07479 seconds
Time After: 0.07638 seconds
Time Taken: 0.00159 seconds
SET lastactivity = 1783095090, location = '/forums/private.php?do=newpm&explain=1&u=113787', badlocation = 1
Time Before: 0.09089 seconds
Time After: 0.09119 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.089903116226196 seconds with 9 queries, spending 0.0083935260772705 doing MySQL queries and 0.081509590148926 doing PHP things.
