Time Before: 0.02532 seconds
Time After: 0.03825 seconds
Time Taken: 0.01292 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03834 seconds
Time After: 0.03875 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03899 seconds
Time After: 0.03912 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.04070 seconds
Time After: 0.04263 seconds
Time Taken: 0.00193 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03920 seconds
Time After: 0.04764 seconds
Time Taken: 0.00844 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.06387 seconds
Time After: 0.06429 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.06743 seconds
Time After: 0.06864 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.06304 seconds
Time After: 0.06894 seconds
Time Taken: 0.00590 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.11707 seconds
Time After: 0.11720 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.22709 seconds
Time After: 0.22831 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.25734 seconds
Time After: 0.25755 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.26455 seconds
Time After: 0.26604 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772738988, location = '/forums/private.php?do=newpm&explain=1&u=113790', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.29050 seconds
Time After: 0.29078 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
