Time Before: 0.00166 seconds
Time After: 0.00239 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00250 seconds
Time After: 0.00308 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00346 seconds
Time After: 0.00370 seconds
Time Before: 0.00455 seconds
Time After: 0.00805 seconds
Time Taken: 0.00350 seconds
Time Before: 0.00378 seconds
Time After: 0.01290 seconds
Time Taken: 0.00913 seconds
Time Before: 0.01518 seconds
Time After: 0.01561 seconds
Time Before: 0.01814 seconds
Time After: 0.01934 seconds
Time Before: 0.01433 seconds
Time After: 0.01959 seconds
Time Taken: 0.00526 seconds
Time Before: 0.02670 seconds
Time After: 0.02683 seconds
Time Before: 0.02886 seconds
Time After: 0.03009 seconds
Time Before: 0.03311 seconds
Time After: 0.03324 seconds
Time Before: 0.03540 seconds
Time After: 0.03687 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113801' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05640 seconds
Time After: 0.05664 seconds
