Time Before: 0.01289 seconds
Time After: 0.01519 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01529 seconds
Time After: 0.01569 seconds
Time Before: 0.01597 seconds
Time After: 0.01614 seconds
Time Before: 0.01684 seconds
Time After: 0.01946 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01622 seconds
Time After: 0.02376 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02819 seconds
Time After: 0.02859 seconds
Time Before: 0.03001 seconds
Time After: 0.03126 seconds
Time Before: 0.02761 seconds
Time After: 0.03148 seconds
Time Taken: 0.00387 seconds
Time Before: 0.04869 seconds
Time After: 0.04886 seconds
Time Before: 0.05671 seconds
Time After: 0.05807 seconds
Time Taken: 0.00136 seconds
Time Before: 0.06318 seconds
Time After: 0.06339 seconds
Time Before: 0.06560 seconds
Time After: 0.06714 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1784797740, location = '/forums/private.php?do=newpm&explain=1&u=113826', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.08245 seconds
Time After: 0.08276 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
