Time Before: 0.02064 seconds
Time After: 0.02761 seconds
Time Taken: 0.00697 seconds
Time Before: 0.02772 seconds
Time After: 0.02843 seconds
Time Taken: 0.00071 seconds
Time Before: 0.02873 seconds
Time After: 0.02912 seconds
Time Before: 0.03006 seconds
Time After: 0.03222 seconds
Time Taken: 0.00216 seconds
Time Before: 0.02920 seconds
Time After: 0.03653 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04500 seconds
Time After: 0.04539 seconds
Time Before: 0.04729 seconds
Time After: 0.04944 seconds
Time Taken: 0.00215 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04437 seconds
Time After: 0.04963 seconds
Time Taken: 0.00525 seconds
Memory After: 2,261.820 KB
Time Before: 0.07848 seconds
Time After: 0.07869 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.14913 seconds
Time After: 0.15042 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.16067 seconds
Time After: 0.16086 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.16414 seconds
Time After: 0.16561 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788887662, location = '/forums/private.php?do=newpm&explain=1&u=113880', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.18180 seconds
Time After: 0.18197 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
