Time Before: 0.02190 seconds
Time After: 0.02680 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02688 seconds
Time After: 0.02829 seconds
Time Before: 0.02867 seconds
Time After: 0.02891 seconds
Time Before: 0.03036 seconds
Time After: 0.03283 seconds
Time Taken: 0.00247 seconds
Time Before: 0.02896 seconds
Time After: 0.03711 seconds
Time Taken: 0.00814 seconds
Memory After: 1,642.430 KB
Memory Used: 1,081.023 KB
Time Before: 0.04391 seconds
Time After: 0.04434 seconds
Memory Before: 2,137.359 KB
Memory After: 2,137.977 KB
Time Before: 0.04671 seconds
Time After: 0.04789 seconds
Memory Before: 2,149.422 KB
Memory After: 2,149.281 KB
Time Before: 0.04317 seconds
Time After: 0.04816 seconds
Time Taken: 0.00498 seconds
Memory Before: 2,129.539 KB
Memory After: 2,262.344 KB
Time Before: 0.08539 seconds
Time After: 0.08557 seconds
Memory Before: 2,815.859 KB
Memory After: 2,816.375 KB
Time Before: 0.10416 seconds
Time After: 0.10544 seconds
Memory Before: 2,904.055 KB
Memory After: 2,904.648 KB
Time Before: 0.11360 seconds
Time After: 0.11378 seconds
Memory Before: 3,540.836 KB
Memory After: 3,541.266 KB
Time Before: 0.11668 seconds
Time After: 0.11827 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,822.414 KB
Memory After: 3,824.102 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=113931' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.13651 seconds
Time After: 0.13679 seconds
Memory Before: 4,288.617 KB
Memory After: 4,288.859 KB
