Time Before: 0.00151 seconds
Time After: 0.00202 seconds
Time Before: 0.00210 seconds
Time After: 0.00251 seconds
Time Before: 0.00285 seconds
Time After: 0.00305 seconds
Time Before: 0.00384 seconds
Time After: 0.00704 seconds
Time Taken: 0.00319 seconds
Time Before: 0.00310 seconds
Time After: 0.01208 seconds
Time Taken: 0.00898 seconds
Time Before: 0.01405 seconds
Time After: 0.01452 seconds
Time Before: 0.01709 seconds
Time After: 0.01835 seconds
Time Before: 0.01339 seconds
Time After: 0.01856 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02388 seconds
Time After: 0.02407 seconds
Time Before: 0.02665 seconds
Time After: 0.02799 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.030533075332642
Time Before: 0.03182 seconds
Time After: 0.03199 seconds
Time Before: 0.03420 seconds
Time After: 0.03564 seconds
SET lastactivity = 1785386392, location = '/forums/private.php?do=newpm&explain=1&u=113932'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05111 seconds
Time After: 0.05141 seconds
Page generated in 0.050179004669189 seconds with 9 queries, spending 0.0089662075042725 doing MySQL queries and 0.041212797164917 doing PHP things.
