Time Before: 0.00698 seconds
Time After: 0.00879 seconds
Time Taken: 0.00181 seconds
Time Before: 0.00887 seconds
Time After: 0.00944 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00976 seconds
Time After: 0.00990 seconds
Time Before: 0.01068 seconds
Time After: 0.01326 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00996 seconds
Time After: 0.01753 seconds
Time Taken: 0.00757 seconds
Time Before: 0.02138 seconds
Time After: 0.02163 seconds
Time Before: 0.02434 seconds
Time After: 0.02655 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02067 seconds
Time After: 0.02679 seconds
Time Taken: 0.00612 seconds
Time Before: 0.03924 seconds
Time After: 0.03946 seconds
Time Before: 0.12737 seconds
Time After: 0.12864 seconds
Time Before: 0.13367 seconds
Time After: 0.13384 seconds
Time Before: 0.13582 seconds
Time After: 0.13727 seconds
UPDATE session SET lastactivity = 1785386419, location = '/forums/private.php?do=newpm&explain=1&u=113933', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.15165 seconds
Time After: 0.15741 seconds
Time Taken: 0.00576 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
