Time Before: 0.00150 seconds
Time After: 0.00255 seconds
Time Taken: 0.00105 seconds
Time Before: 0.00267 seconds
Time After: 0.00317 seconds
Time Before: 0.00336 seconds
Time After: 0.00349 seconds
Time Before: 0.00417 seconds
Time After: 0.00666 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00354 seconds
Time After: 0.01011 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01196 seconds
Time After: 0.01217 seconds
Time Before: 0.01466 seconds
Time After: 0.01582 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01127 seconds
Time After: 0.01600 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02163 seconds
Time After: 0.02178 seconds
Time Before: 0.02352 seconds
Time After: 0.02475 seconds
End call of global.php: 0.026408910751343
Time Before: 0.02751 seconds
Time After: 0.02765 seconds
Time Before: 0.02965 seconds
Time After: 0.03109 seconds
SET lastactivity = 1783505913, location = '/forums/private.php?do=newpm&explain=1&u=113942', badlocation = 1
WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.04339 seconds
Time After: 0.04373 seconds
Page generated in 0.042496919631958 seconds with 9 queries, spending 0.0077764987945557 doing MySQL queries and 0.034720420837402 doing PHP things.
